Taskalpha 3252ci Memory low cannot scan
  • Doug James
    • Jan 2012
    • 935
    [Misc] Taskalpha 3252ci Memory low cannot scan
    Hello,
    I haven't been to this call yet but this is what the customer is telling me.
    The copier is saying "Memory low and cannot scan"
    I am new to these machines and not sure where to start Thanks for any suggestions
    • 22997
    Re: Taskalpha 3252ci Memory low cannot scan
    We'll need some details about the scanning:
    email? SMB? FTP? USB stick?
    color? monochrome?
    resolution: 200dpi? 300dpi 400dpi? 600dpi?
    if email: email server attachment limits?
    and about the machine:
    current memory loaded/available?
    so many questions ...
    • Doug James
      • Jan 2012
      • 935
      color? monochrome?
      Thanks so much, Appreciate the heads up THANKS !!
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1867
        Rebooting usually clears the memory and will fix the error.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • PrintWhisperer
          • Feb 2018
          • 465
          MM340 is not directly noted to effect scanning, but may alter the situation my removing some allocated memory from the print jobs.
          Try changing 'Adj Memory'->Image from 0 to -50 (remove 50Mb from Print allocation), reboot and test.
          It could easily need to be changed to +50 as well, I have no actual experience changing MM340 but it has been recommended in situations like this.
          "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
