Reading the Sub codes in paper jam error
  • photocopier.technician
    • 27
    Hello,
    I would like to know if someone can explain to me how to read the sub codes on printers when a paper jam occurs. For example i have a machine with error J0000 and below the jam error code it indicated 05,10. I do have the service manual but i cannot find how to read those codes.
    I know the next step to troubleshoot this error is to do U031 and check the sensor status, still i would like to know about the sub codes meaning.
    • 23009
    Re: Reading the Sub codes in paper jam error
    What model did you say this was? =^..^=
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1889
      In the xx53ci manual (which I assume is your display), Page 6-14 is where it starts to explain how to read the event log. This is the best way to figure out what tray, output etc was happening when it jammed.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
        • 16416
        Originally posted by photocopier.technician
        Hello,
        Thanks in advance[ATTACH=CONFIG]55837[/ATTACH]
        It's most assuredly is in the service manual. The top number is the Jam Code which suggests the cause of the jam and the bottom numbers are the position code, telling you the location of the jam in the machine.
          • 16416
          JOOO0 means the power was turned on with a jam in the machine.
          05 is a jam @ cassette 3 or 4
          10 is a jam @ paper conveying unit
            • 27
            Thank you for the replies.
            The model is TaskAlfa 6003i. Can you please tell me in which section of the Service Manual i can find the detail about the codes.
            Thank you
              • 23009
              I think what you asking for is on pg 7-89, but honestly you'll get much more useful information from the event log. =^..^=
                • 27
                Thanks BlackCat thats what i was looking for. And thanks everyone for their informations.
