Just to wrap this up. I think I have this right. The original yellow drum that came in the machine can't be swapped around because it stores data that will cause CQ issues. It's marked with a yellow circle with a black dot.
A new yellow drum ordered from Kyocera will have a yellow circle with a red dot and can be swapped around.
Original developer replaced with good used, first print out was banded. Original drum replace with new DK-8350, first print out banded. Ran all calibrations in service mode. Drum conditioning and blanking lamps working. Going back today with used LSU.
That looks like its form a troubleshooting guide of from a class handout. That's good to know. Something to lookout for when dealing with a 2552ci or 3252ci. Many of these out in the field are usually low mileage. So if I swap the yellow drum and it has a sticker and then it codes, its an original.
stsacer I have attached the handouts that are included in any new developer unit, drum unit, transfer belt, or fuser unit. In this case I have provided the ones for drum and developer unit replacement. I find these handy as they provide step by step instructions on what maintenance modes to use when installing a new sub assembly. When I have to use a used sub assembly or I am swapping for testing, I usually do most of the adjustments, not all.
These handouts usually also include Image Adjustments. Whenever I take out inspect and/or clean the developer, drum, charger roller, or transfer units, I run the Image Adjustment. Never hurts.
I don't know why Kyocera changed the handouts. Prior to the xxx2 series, the handouts included adjustment instructions for all the sub assembles for the series (as seen in the one I have included for the xxx0 and xxx1 series).
Ordinarily I would say yellow developing based on your samples. What is the repetitive interval on the pattern? 37.5mm = primary charge, 50.2mm = developing =^..^=
