Taskalpha 4002i DP Registration
  • Doug James
    • Jan 2012
    • 935
    [CQ] Taskalpha 4002i DP Registration
    I am new to these machines and having trouble figuring out how to set the Registration correctly. I thought it was in service mode but can't find it anywhere. Any help pointing me in the right direction would be very appreciated.
  • allstar59
    • Oct 2012
    • 64
    Re: Taskalpha 4002i DP Registration
    U066 Adjusting the table scanning timing Adjust the lead edge timing for table scanning
    U067 Adjusting the table scanning center
    line
    Adjust the center line for table scanning
    U068 DP scanning position adjustment Adjust the starting position for DP scanning
    U070 DP magnification adjustment Adjust the magnification for DP scanning
    U071 Adjusting the DP leading edge
    Timing
    Adjust the DP scan timing
    U072 Adjusting the DP original center Adjust the center line for DP scanning
    • Doug James
      • Jan 2012
      • 935
      line
      Timing
      Wow, sure do appreciate that !!! Thanks for taking the time to type that out. Ive been looking for an hour or 2 but for some reason it wasn't easy to find THANKS !!!!
      • subaro
        • Oct 2010
        • 1274
        The way I do it though is to make sure the center for the trays are done first with 034, then the margins 402, then go on to the rest as pointed out by the previous poster. If the trays are not centered ,then you would go all over the place trying to figure out why you are not getting results.
        • KYO_OEM
          • Aug 2011
          • 719
          SP 071 won`t work if SP 075 would set to "ON"
          Sorry, wrong system informations, have had it several times for xx54 ci range.
          But also helpfull in future i think
