p2040 Toner smudging and not fusing onto paper of first page of print job
  • Russell
    • 12
    Hello Everyone,
    One of my p2040's is malfunctioning. The print on the first page of a job after the printer has been idle for a while is smudging and rubs off easily. Subsequent pages of the same job fuse and print perfectly. So I presume this issue is caused by the fuser roller not reaching the correct operating temperature to fuse the toner onto the first page.
    I have checked the thermistor, it's resistance reduces when I apply heat to it, so the thermistor appears to be working ok. I have checked both thermal cut-out pots on the fuser heater circuit as well.
    Any suggestions would be greatly appreciated.
    Many thanks,
    Russell
  • Russell
    • 12
    Re: p2040 Toner smudging and not fusing onto paper of first page of print job
    Is it possible to adjust the fuser temperature setting? I couldn't see this option in the adjust/maintenance menu. Thanks,
    • taskalfa
      • Jun 2011
      • 97
      • Russell
        • 12
        5 years old, 46,000 pages
          • 23009
          That's great! They rarely get 46K. The Teflon sheet dries out, causing jamming usually earlier than 46K. =^..^=
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1890
            Yep it's the sliding sheet. You either get Jam 42xx, smudges, or a loud popping noise when the drive gear slips due to the drag on the fuser.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
