3551ci: Solid Black page
    • 16416
    Got a call today for solid black pages. The customer said this happens when making copies from the doc. feeder and platen glass. Also when printing from PC. When I got there it was printing fine and couldn't reproduce the problem.
    Anyone seen this before?
  • copier tech
    • 8176
    Re: 3551ci: Solid Black page
    Did they save you any printed samples of the fault ?
      • 16416
      Well, they had me dig 'em out of the trash can. The full pages were black.
        • 23009
        The thing to pay attention to is whether there was an image void on the all black page. If there is an image void, the laser is functioning, and you have an image processing issue. If there is no image void, either you have a primary charge loss or a laser failure ... or (unlikely) both.
        Is the page just K: black or CMYK: composite black? If you're getting CMYK edge to edge, most likely the HVT is shutting down. If it's only K: black I would suspect the K primary charge unit or drum unit.
        And yes, all these conditions can be intermittent. =^..^=
        • Samanator
          • Sep 2017
          • 579
          I just had this kind of problem on a 4551ci with 923K on the total counter. This was maddening because I went out there and they had some sample black copies (did it when it copied or printed). However I could not get the machine to make black copies for me. I went back the next day for the same thing and again the customer had samples (and words) but the machine still would not do it for me.
          Intermittent problems are the worst.
          To cover my ass with this customer (and my boss), I called Kyocera support mostly to get a case number. The guy I talked to did suggest I start by looking at the optics and the CCD before I went to see if it was an engine problem.
          What I did was unplug the machine then pull out all the developer and drums and the transfer belt unit and that forced me to take off the right side door. I cleaned (vacuumed) all these units paying close attention to all contact points. Many times the transfer belt and the right side door never get a real good cleaning. I put a hard vac on the inner cavity putting brush and vac on all contact points. There is a PCB that the drums and developer units plug into. I put the brush and vac to that as well. That PCB always seems to get toner on it and I don't think that does anything any good. It also doesn't help that this customer buys their own toner and its never OEM. I also cleaned all the charger rollers. I did a deep clean on the optics and re-seated the plugs on the CCD when I gave the lens a wipe.
          I put it all back together and fired it up and it worked.
          This happened last Wednesday and had there been a problem we would have heard right away as this machine is not under service agreement.
          So maybe a deep clean on an old machine may be in order.
            • 16416
            You talking about the image void around the entire page? Yes, it was there. Not sure if the image was black or composite black. What's the best way to tell the difference between the two blacks? The black pages looked less dark than true black.
            I get the theory behind what you're saying though. Good stuff. AS ALWAYS. I'll post any updates when I can.
              • 16416
              Interesting. I'll be sure to hit all the hotspots. Thank you.
                • 30310
                How's the power ? Anything else on the same line ? Surge suppressor? Hows the maintenance on this? Anything close to be replaced?
                Now that your a authorized Kyocera dealer thank GOD and have tech support and access to training suggest you open a ticket.
                • copiertec
                  • Jan 2016
                  • 2211
                  We have some lightly used color drums/developers/ fuser unit/ transfer unit that was pulled from a working 3051ci, I believe they all have under 20k on them. If you need any of them make me an offer and we can ship them out to you.
                    • 16416
                    Thanks for the offer. A while back I bought several low meter machines (very cheap) just for parts and supplies. .
                    So, I returned to the customers office this morning. The black drum and DV had about 500k. Ditto for the transfer belt. I replaced those and all of the PCR's. I cleaned/examined all the HV contacts.
                    This will be a waiting game as it's an intermittent problem. I feel pretty good about it. We'll see.
                    I want to thank everyone that gave advice in this thread. It's always appreciated greatly.
                      • 23009
                      K: black (like on a monochrome print or copy) is always slightly less dark as CMYK, composite or "rich black".
                      Printers will often introduce varying amounts of cyan and magenta to produce a richer, darker black.
                      Take a look at pg 8 of the ANSI A 11% color test pattern, which shows various rich blacks, compared to K black & composite black.
                      • Samanator
                        • Sep 2017
                        • 579
                        This morning we got a call from the customer with the 4551ci. The problem came back. It goes away after a reboot, but comes back.
                        The machine has near a million on it. They now wish to upgrade.
                        Fine by me.
                        Still it has something to do with the CCD or black dev unit.
                        Aftermarket toner doesn't help.
                          • 16416
                          I looked at page 8. Very interesting. The pages that I pulled out of the trash can are a spot-on match with composite black - cyan 100%, magenta 100%, yellow 100% and K 0%.
                          So that' means most likely the HVT is shutting down, correct?
                          • tsbservice
                            Field tech
                            • 8022
                            I'm thinking replacing K drum unit would solve it.
                              • 23009
                              Yes, the HVT is definitely shutting down. BUT, why is it shutting down? Is one of the charge rollers arcing to make the HVT shut down? Is it the HVT failure?
                              Your best odds of solving this in a single visit is to replace the (4) charge rollers and the HVT. =^..^=
