Kyocera M6235cidn rainbow prints
  • Samanator
    • Sep 2017
    • 579
    You ever seen a M6235cidn do this? This is a status page. Does this on print jobs as well.
    Re-seated drums, developer units, and transfer belt with out change.
    Thanks in advance for any help.
  • scottybbb
    • Dec 2010
    • 126
    Re: Kyocera M6235cidn rainbow prints
    Check the contacts for the transfer belt on the inside front of the machine. If one of them is pushed inside the machine this can happen.
      • 23009
      Start by re-seating all the units. Quite often it's just a poor charge connections. If that doesn't help, check the contact springs behind the HVT.
      In the worst case scenario, one of the components that uses charge may be shorting out, briefly shutting down the HVT. Maybe developer spacers, maybe primary charge arcing. If you identify a specific color defect replace BOTH drum and developing units of that color, so that the arcing does not continue. =^..^=
        • 16416
        In the worst case scenario, one of the components that uses charge may be shorting out, briefly shutting down the HVT. Maybe developer spacers, maybe primary charge arcing. =^..^=
        A few weeks ago when I was having a problem with solid black pages on a 3551ci, didn't you post an example of this "rainbow" problem? Or am I mistaken?
          • 16416
          I thought I remembered this post by blackcat:
          Thanks. The symptoms can vary widely depending on what machine.
          This was a Hanabi with broken yellow developer spacers. The drum was arcing to the developing roller causing the HVT to shut down for a few seconds at a time. Note: There aren't any yellow bars (that how I diagnosed the yellow developing unit):
          3551ci: Solid Black page-test-sample-jpg
          I'm sure there are more samples somewhere, I cannot seem to locate right now. =^..^=
            • 23009
            I thought that sounded familiar ... it seems like charge rollers solved your issue, yes? =^..^=
              • 16416
              Yes, sir. I changed the charge rollers and it's been good. Thanks for your help.
              • KYO_OEM
                • Aug 2011
                • 721
                Have had this on M6525cdn and new dk for yellow + hvt pcb needed.
                DK only didn`t solved it.
                For Mebius Range (successor from Gemini), mostly yellow dk + dv needed
