can't connect to the web page of the kyocera tasfalka 4501
  • ESSN-TIC
    • Nov 2022
    • 8
    Hello
    please i want your help to solve this problem.
    I can't connect to the kyocera tasfalka 4501 web page, when I ping it goes well..... But I can't connect to the page, I changed my ip address, browser and even factory reset.
    Thanks for your help
  • GIUBOSS
    • 1436
    Re: can't connect to the web page of the kyocera tasfalka 4501
    Allowing both HTTP and HTTPS
    • PrintWhisperer
      • Feb 2018
      • 473
      Please refer to the attached bulletin, "Measures if you cannot access Command Center"
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • ESSN-TIC
        • Nov 2022
        • 8
        thanks I've done this before but it still doesn't work...
        • ESSN-TIC
          • Nov 2022
          • 8
          Thanks very much........
          • dalewb74
            • Feb 2018
            • 1157
            unplug from the network. ping that IP address. i bet something else on the network is using the that IP.
            • nathicana
              • Aug 2008
              • 335
              I've found Internet Explorer is difficult to use because it is so outdated.
              Here's an open source browser that supports TLS 1 so you can easily get into the older machines to turn on TLS 2 and SHA 1, SHA 2
              The Pale Moon Project homepage
              • rapo_tech
                • Feb 2019
                • 114
                5 year old firefox also resolves this problem Download Old Versions of Mozilla Firefox for Windows - OldVersion.com
                • sparkycivic
                  • Apr 2017
                  • 348
                  *sigh...
                  it's solved long ago
                  taskalfa 5501i scaner
                  important part:
                  Originally posted by sparkycivic
                  You can re-enable the TLS deprecated access in Firefox by going to about:config and searching for the setting " security.tls.version.enable-deprecated " and change the setting from "False" to "True"
                  Probably a similar thing exists in the other browsers too, but i don't use those.
