TA3551ci - Copy/print slides image
  • Tony91
    • Apr 2023
    • 2
    Greetings, it's been quite a few tries now on a TA3551ci we have on-site at a client's building and we can't wrap our head around what's causing the issue. Scan is fine, when you copying or printing, images slide off the sides of the paper, never twice the same, sometimes left/right sometimes up/down. We checked the whole paper path with no luck in finding any obstruction or missing/dirty sensor. Worth mentioning the same machine won't print in duplex, not even a page. For reference, please check the images attached. Thanks in advance!
    • 23009
    Re: TA3551ci - Copy/print slides image
    Have you done anything yet? =^..^=
    • KYO_OEM
      • Aug 2011
      • 720
      we are talking about a very old system.
      I would take care for the registration clutch at first.
      • Tony91
        • Apr 2023
        • 2
        As per original post, the whole paper path has been tested, tried with different trays and the bypass, with no difference, feels like it's happening around the fuser section, which might make sense with the user suggesting the registration clutch, will take a look at that ASAP, thanks for the suggestion.
        • Ropariva
          • 678
