F1D6 Error when scanning duplex on 508ci
  • thinkink
    • Apr 2016
    • 62
    Has anyone seen this? Just getting it when scanning 2 sided. Not happening on 1 sided. Kyocera CS-508ci
    • 23009
    Re: F1D6 Error when scanning duplex on 508ci
    It isn't much, but this is what I've got:
    CF1Dx: An error is detected at the Image memory management section.
    I don't have a manual for a Perseus 2, but I suspect that you might find memory on the SHDPWB or on the main PWB. It's even possible that the memory is replaceable. =^..^=
    • PrintWhisperer
      • Feb 2018
      • 473
      For the DP-5130 Dual scan feeder, there is 500MB of memory on the PWB DPIF ASSY 303R894050.
      Reseat the board and possibly replace (CIS-DPIF) SATA cable then try replacing the above interface board.
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • KYO_OEM
        • Aug 2011
        • 721
        we have had similar error because of not well fitted PWB DFIF Assy.
        Reconnect DPIF PWB and SATA cable.
        • thinkink
          • Apr 2016
          • 62
          Thank you we found the board wasnt seated correctly.
