Compatible Toner affects OEM developer??
  • Copier Mechanic
    • Mar 2023
    • 89
    Hello my friends,
    So today I overheard my boss talking to my service manager about compatible toners (3162) which is for M3645idn / M3145idn / P3045dn is affecting the developer. They are having to constantly swap out the developer too often. They want to start using OEM toners from now and on to prevent that problem.
    Now my question is: How does compatible toner uses up the developer so quick that it needs replacement very soon? If anyone recognizes this issues, can you explain why this happens? Thanks in advances!!!!
  • darry1322
    • Oct 2010
    • 817
    Re: Compatible Toner affects OEM developer??
    Originally posted by Copier Mechanic
    Hello my friends,
    It doesn't use up developer. The new toner from the new bottle doesn't mix well with the toner still left in the developer unit causing grey background and streaking.
    At this point you can completely clean the developer unit of ALL toner and insert a new toner to correct the issue or replace the developer with a new unit and toner.
    Or just use OEM and not have the problem in the first place.
    • Ropariva
      • 680
      • Gab
        • Aug 2015
        • 671
        Kyocera machines have issues with compatible toner. If you use compatible toner try to find one that works fine with this macjines. Also use the same toner not going from one toner to other.
        Clean the developer unit from remainning toner and then use U130 /
        If there is a problem with a bad toner you have to clean developer unit from remainning toner and U130. Even if you indent to use compatible toner id better this firste toner to be genuin and then to use compatible but good quality toner . Keep using the same toner
          • 23009
          Not much that I can add to that.
          Only that toner serves multiple functions in a copier:
          1) it forms the visible image on the paper
          2) it lubricates cleaning blade(s)
          3) it must fuse within a specific temperature range
          4) it must remain granular in the toner feed system, in the developing unit, and in the waste collection system.
          5) it has very specific electronic & magnetic properties
          If any one of these varies too far from the standard, you may see:
          1) poor image quality
          2) flipped cleaning blade(s) or toner buildup on drum or transfer belt
          3) poor fusing or toner adhering to fuser rollers
          4) seized up toner feed auger(s), developing augers(s), or waste collection auger(s)
          5) toner dumping in the machine, poor image quality. When developer powder is present: poor regulation of developer density.
          All of these are extremely common. That discount price that you pay for the cheap toner does not begin to cover the costs of trying to maintain the machine running it. =^..^=
