kyocera 3510i blurred image
  • alpertevfik
    • Sep 2006
    • 38
    hello kyocera 3510i machine starts to give blurry image output after 1-2 prints. I tried drum unit, developer unit, transfer roller, laser unit, HVT card but the result did not change. Print samples are attached. I would be glad if you could help.one.jpgtwo.jpgthree.jpg
  • piksel1983
    • Oct 2018
    • 38
    Re: kyocera 3510i blurred image
    PCR or drum unit where new that you put in?
    Wysłane z mojego 22111317PG przy użyciu Tapatalka
    • alpertevfik
      • Sep 2006
      • 38
      I İnstalled the units of a machine with a numerator of 5000 pages.
      • Ropariva
        • 680
        Looks like the type of degradation you get when there is dampness in the machine and typical of when a machine has sat unused for quite some time. Sometimes the drums recover and are ok but often not. They seem to have a life not only in rotations, but in years
        Try doing a few drum refreshes and a dev refresh. If that recovers it then fit the dehumidifier in the tray, turn on the code U327 to mode 2 and make sure the customer keeps the machine plugged in and switched on. Otherwise you are gonna need a brand new drum.
        Sent from my iPad using Tapatalk
        • alpertevfik
          • Sep 2006
          • 38
          We tried the drum unit on another machine, it worked without any problems. The fault is elsewhere, but we cannot detect it.
          • GIUBOSS
            • 1436
            Make sure you stop printing before the sheet enters the fuser and see if the problem persists, also run FW update
            • alpertevfik
              • Sep 2006
              • 38
              I tried... unfortunately no results. I also changed the engine boards. The problem persists.
                • 16416
                Genuine toner?
                I agree that it looks it could be moisture. Or a fuser problem. Have you tried changing the transfer roller?
                It would be helpful if you printed out the internal test charts. - U089.
                • copykat93
                  • Oct 2021
                  • 281
                  Following this one... Very interesting... Grounding issue?
                  • piksel1983
                    • Oct 2018
                    • 38
                    Please swap pcr and show sample
                    • Step
                      Senior Technician
                      • Sep 2015
                      • 42
                      Hi
                      I had similar issue and it turned out to be the fuser unit temperature was too high. Check your paper settings and make sure it is set to the correct paper thickness and gsm range. Check your default fuser temperature in service manual and adjust the fuser temperature in Maintenance mode if it is not the same.
                      In my case new fuser did not help because it was caused by settings and not hardware.
                      What I also sometimes do for good measure is to do U907 backup and then run factory reset. Having multiple technicians working on machines sometimes lot of the settings was changed that cause problems later.
                      Please let us know your findings.
                      Sent from my SM-A736B using Tapatalk
                      • alpertevfik
                        • Sep 2006
                        • 38
                        Tried transfer roller, pcr, fuser unit, original toner. FW is up to date. u021 expelled. The problem persists. We are trying to find a solution.
                        • piksel1983
                          • Oct 2018
                          • 38
                          In my opinion theres a problem with charging a drum. If u r 100% sure that drum&pcr are ok there could be a dev problem or hvps.
                          Are these prints one by one?
                          Did u tried changing u100?
                          • KCJeff
                            • Apr 2022
                            • 7
                            How's the humidity in the room? How damp is the paper?
                            • alpertevfik
                              • Sep 2006
                              • 38
                              The prints were taken in series. I'm pretty sure it's a drum charging issue. However, we could not understand the reason for this. Changed the main board. The result is the same.
