kyocera 3510i blurred image
Re: kyocera 3510i blurred image
A dev refresh should help. Every morning after you start the machine run dev refresh and drum refresh, then you should print without problemsComment
I emptied the developer, cleaned the tank, adjusted the u130. 10-12 prints were good, then it started to print badly again. I disassembled the chassis of the machine, checked and collected it. The problem persists.Comment
