kyocera 3510i blurred image
  • alpertevfik
    • Sep 2006
    • 38
    Re: kyocera 3510i blurred image
    Originally posted by KCJeff
    Odadaki nem nasıl? Kağıt ne kadar nemli?
    Another machine is working in the same environment.
    • nikolai.aleksie
      • Feb 2016
      • 177
      A dev refresh should help. Every morning after you start the machine run dev refresh and drum refresh, then you should print without problems
      • Ropariva
        • Mar 2016
        • 656
        Are you sure the dev is rotating? You say it starts ok but degrades after a few pages? Confirm dev is running and dev bias connections.
        Sent from my iPad using Tapatalk
        • marvin_PL
          • Jun 2012
          • 24
          #19
          Turn on the cassette heater, it's on the back of machine near power cord,under plastic black cover
          • alpertevfik
            • Sep 2006
            • 38
            #20
            I emptied the developer, cleaned the tank, adjusted the u130. 10-12 prints were good, then it started to print badly again. I disassembled the chassis of the machine, checked and collected it. The problem persists.
