Kyocera M6230cidn with points and lines, black drum unit is with damaged surface
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    I've already ordered the black drum unit because of this problem but I'd like to know why is this happening?, I've already visually checked the (black) drum unit and other parts and there no seems to be a visible cause for the drum to get these little scratchs/points which causes to leave a "ant trail" on printouts. (Kyocera color M6230cidn).
    Thanks in advance for your advice,
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
    • 22999
    Re: Kyocera M6230cidn with points and lines, black drum unit is with damaged surface
    An image might help.
    I can take a wild guess, that you're see toner fused to the black drum. It can be cleaned off, but comes back. The real issue is that the internal temperature of the machine gets warm enough to fuser black toner to the drum. To keep the internal temperature lower and preserve the life of other consumables, set the sleep timer to 5 minutes or less, or Silent Mode (or both). =^..^=
      • 16328
      How did you ever figure that out, bro? That seems like it'd be a tough one to diagnose.
        • 22999
        The first clue was that it mainly affected the black drum ... closest to the fuser. The temperature probe confirmed it. If you examine one of those drums closely, you'll see that the toner fused to the surface is in narrow bands crossfeed (its the toner in the drum cleaning unit fusing). And no, Kyocera was not particularly transparent about it. They came up with 3 or 4 different mods on the drum coating. The only real fix would be a software fix to run the fans longer, and keep the temperature down. =^..^=
          • 16328
          Good work. What temperature probe are you using? I may need to get one. Sounds like it could come in handy.
          • rapidocument
            Multibrands Tech
            • Jul 2012
            • 381
            Here are the photos of the drum and the printouts, IMG-20230725-WA0014.jpgIMG_20230816_074921.jpgIMG_20230725_140038.jpg
            • Larhal
              • 564
              Originally posted by rapidocument
              Here are the photos of the drum and the printouts, [ATTACH=CONFIG]59271[/ATTACH][ATTACH=CONFIG]59272[/ATTACH][ATTACH=CONFIG]59273[/ATTACH]
              I also have seen the same thing that Blackcat described.
              I would try to clean the marks from the drum and also clean the PCR, Are the drum marks scratches or bumps?
              Are you using genuine toner or compatible?
              Larhal
              If all else fails read the Service Manual!
              If that fails, meet me at the pub and we will discuss it.
              • rapidocument
                Multibrands Tech
                • Jul 2012
                • 381
                They are scratches, drum coating is peeled off as you can see in the photo, and am using genuine OEM toner.
                  • 22999
                  There are a couple of different ways you can go:
                  If the thing you're try to take the temperature of is line-of-sight, you can get a temperature gun quite cheaply ($25):
                  If the thing you're trying to measure is not line-of-sight, but you can touch it, even inside the machine, this little thing plugs into my meter. It's a dielectric temperature probe:
                  SA1-IEC| Adhesive Fast Response Surface Thermocouples, High Temp
                  Here's an example: I had a Mita DC2525 at a school. They had tucked it into a low height closet under a stairway (the kind with the door cut at an angle?). They didn't like the sound of it running, so they would close the door to the tiny closet. They were experiencing some weird fusing issues, the image would re-print multiple times down the page. So what I did was ran my temperature probe under the door, and taped it to the front cover. I started a job of 200 duplex images, closed the door, then watched the temperature. I stopped the experiment when it hit 120F inside the closet. It would have gotten hotter, but I had proved my point. =^..^=
                  • darry1322
                    • Oct 2010
                    • 817
                    They have a DK-5140A drum (302NR93180) that is supposed to help with these marks.
                    We've been using them for a while. Results are mixed.
                    • copydocinc
                      • Mar 2015
                      • 263
                      So is Kyocera honoring the warranty for these drums or are they doing something else about it? I have a couple that had to be replaced within 8 months and only 25,000 pages total. Exactly the marks you talked about.
                        • 22999
                        I don't know about the warranty question, but adjusting the sleep timer is the only long term solution.
                        • copydocinc
                          • Mar 2015
                          • 263
                          I did set the sleep timer to 1 minute, when I set up the machine out of the box.
                          I didn't notice the other setting you mentioned "silent mode" Is that in the same area, to change its setting?
                            • 22999
                            It may be there in System Menu > Adjustment Maintenance > Quiet Mode.
                            Funny, I never noticed that the earlier machines called it "Quiet Mode". =^..^=
                            • KYO_OEM
                              • Aug 2011
                              • 710
                              Mebius drum nightmare...
                              Drum Dash Marks from bk or colored background because of broken surface layer
                              Quite mode can be helpfull, but most not be helpfull
                              Depended to the kind of usage it can happen or not.
                              See extract from related bulletin:
                              Corrective measures for the vertical line image (Drum dash mark). In case of the following condition, in order to improve
                              further, set the drum unit (No.1) exclusively for the drum dash mark prevention as a service part in the field (Note)
                              - Print volume is high
                              - Repeat the continuous high volume print job
                              - Repeat the job in a short interval
                              - Depending on the above usage condition or the usage environment, machine inside temperature becomes high.
                              Also mixed experience with special dk unit, i have.
                              Sometimes it can help, sometimes not
                              By the way:
                              You do not need run any measurements for internal temp, by service status page you can see current values.
                              It`s hidden on the 2nd page.
                              Do not use this drum for CMY, because there you will get broken drum surface layer in the early stage.
                              More often and much more against usage from "normal" color drum.
                              The pressure from the cleaning blade would increased and the expected lifetime shorten THX KYOCERA
