Kyocera ECOSYS M5526cdw slow printing
  • diedux
    • Jan 2017
    • 124
    #16
    Re: Kyocera ECOSYS M5526cdw slow printing
    How about cables? I remember going out for a slow printing call, and the secretary had been rolling over the network cable with her chair for the last 5 years or so, and the cable was flattened. It wasn't very pretty. A new network cable fixed that one. =^..^=
    I also had a lousy cable issue. The main symptom was as super slow printing. At first, all focus was on Kyocera. The port to which the printer was connected drilled HP switch CPU at 100%. And all this happened at random intervals around 50% of the time. Of course, we understood this was a cable problem after changing the device to a brand new...
    • nathansipe
      just another tech
      • Aug 2009
      • 122
      #17
      2 different machines in different rooms on the same network doing the same symptoms all of the sudden. That's surely a network issue. Connect the laptop directly to bypass network to print and prove each Kyocera is fine. Then troubleshoot the network cables, switch ports etc.
      I know others have said check that it's a TCP/IP port not a WSD, but you keep saying its a not a WSD driver. Maybe just the wrong term, but double check it's not set a WSD in the PORTS, not in the driver. A KX driver can still by set to WSD by Microsoft. You can also turn off WSD printing in the command center of each mfp to be certain.
      Continuous ping of course is another great tool to make sure it's keeping its connection and the network isn't dropping it due to a bad cable, dual ip, etc.
      Good luck.
      Best rule for troubleshooting.
      K I S S Keep It Simple Stupid
      • kuby
        • Oct 2007
        • 1408
        #18
        Yea they are 3 hours away..
          • 30284
          #19
          You can use remote to web in
          I use zoho it's free or TeamViewer
          • kuby
            • Oct 2007
            • 1408
            #20
            I have remoted into the Server and both printers and do not see anything out of the norm. Still looking.
              • 30284
              #21
              Load the pcl mini driver and test
              It's basically a striped down driver it only sends the data
              No extra junk
              • ihatefinishers13
                Senior MFP Technician
                • Feb 2020
                • 709
                #22
                This is why you rule out the machine early on and put it on the customer's IT or network provider. HATE network calls that they keep saying it's the printer's fault when it ends up being their network.
                • Lunatech
                  • Oct 2012
                  • 208
                  #23
                  ... you can connect a laptop directly to the printer.
                  This is where I always start. Once I determine if it is a printer problem or a network problem I proceed. If it is a network issue I find out if they have some one on staff or contracted to handle it. If they do I'm out. Most oft it is a network issue and is easily resolved by scrubbing and reloading the driver. Not always.
                  • ricohmaina
                    • Dec 2011
                    • 21
                    #24
                    I'd do a 917, 021, 917 then resend the job.
