Color Density Issue on Kyocera P8060cdn
  • tzim
    • Sep 2023
    • 15
    Having some issues with color density being lighter towards one side.
    Attached is a photo of a letter sized paper folded over to show the difference in density.
    This affects all colors. Would this indicate a problem with the transfer belt? The paper is fed sideways (from the long side).
  • ntbann
    • Jan 2012
    • 623
    Re: Color Density Issue on Kyocera P8060cdn
    It could be your LSU polygon tips.
    • dalewb74
      • Feb 2018
      • 1118
      actual kyocera parts? toners?
        What's the count on the supplies?
        • tzim
          • Sep 2023
          • 15
          New machine bought 2 months ago.
          All OEM parts and toner.
          5000 prints.
            I can't tell a whole lot from you example. Can you print all the solid images and post them? Thanks.
              • 22934
              P8060cdn is the printer version of Iris.
              What have you done so far? =^..^=
              • tzim
                • Sep 2023
                • 15
                Attached are further prints from U089. There this issue is not evident. Seems to affect only light fill.
                So far I have tried the various refresh, cleaning, calibration options under maintenance.
                Also played around with the service mode options but since the service manual is not available online for this model I have not gotten very far.
                "P8060cdn is the printer version of Iris."
                Had to look up what Iris was. Does that mean it's complicated, wasteful but produces beautiful prints?
                  [ATTACH=CONFIG]59622[/ATTACH]
                  Series Name Product Code Models
                  Alphard I Gaia 2LL,2LJ,2LH CS-3500i, CS-4500i, CS-5500i
                  Alphard I Zeus 2LG,2LF CS-6500i, CS-8000i
                  Alphard I Venus 2LK,2LN,2LM,2LC CS-3050ci, CS-3550ci, CS-4550ci, CS-5550ci
                  Alphard I Mercury 2LB,2K9 CS-6550ci, CS-7550ci
                  Alphard II CS-3501i, CS-4501i, CS-5501i
                  Alphard II CS-6501i, CS-8001i
                  Alphard II CS-3051ci, CS-3551ci, CS-4551ci, CS-5551ci
                  Alphard II CS-6551ci, CS-7551ci
                  FalconI 2DF RI-2530, RI-3530, CS-4030
                  FalconII 2FG,2FF,2FD CS-3035, CS-4035, CS-5035
                  FalconIII 2GN,2GP,2GR CS-3050, CS-4050, CS-5050
                  FalconIV 2KR,2KS CS-420i, CS-520i
                  Gemini 2KW,2KX,2LW,2LX FS-C2026MFP, FS-C2126MFP, FS-C3040MFP, FS-C3140MFP
                  Hanabi 2KZ,2K0 CS-205c, CS-255c
                  Harrier 2FB,2FC CS-6030, CS-8030
                  Harrier2 2KP,2KN CS-620, CS-820
                  Kyo-Shiba 5JN CS-550c, CS-650c, CS-750c
                  Matsuri 2L3,2K3 CS-255, CS-255b, CS-305
                  Saturn 2JZ,2JX,2JV,2H7,2KY CS-250ci, CS-300ci, CS-400ci, CS-500ci, CS-552ci
                  Stratos 2JB,2JC,2H0,2HZ,2K5 CS-2540, CS-3040, CS-2560, CS-3060, CS-300i
                  Voyager 2FZ,2F0,2HC CS-C2520, CS-C3225, CS-C3232
                  VoyagerE 2JL,2JJ,2JG,2JD CS-C2525E, CS-C3225E, CS-C3232E, CS-C4035E
                    • 22934
                    Lol. Iris must have come out after I sent you that list. Iris is the name for a specific family or series of machines built off of the same chassis & technology. =^..^=
                      • 22934
                      Oh, one question I forgot to ask: Are you using Genuine Kyocera toner? Generic toner could cause that.
                      If the effect is as subtle as you say, I would start with new primary charge rollers, cleaning laser slit glasses, and full calibrations again. =^..^=
                      • dalewb74
                        • Feb 2018
                        • 1118
                        i asked the same question. they stated yes that the machine was only a couple months old.
                          • 22934
                          Sorry, I missed that.
                          Just out of curiosity, I wonder how long it took to run those 5K prints? =^..^=
                          • tzim
                            • Sep 2023
                            • 15
                            Thank you for the suggestions. Will look at that those when it gets worse. Feeding the paper short edge first circumvents the problem for now.
                            Yes, using OEM toner (starter cartridges).
                            Took about a month to reach 5,000.
                            • Gab
                              • Aug 2015
                              • 657
                              Perhaps high voltage. Maybe there is toner on high voltage clean it otherwise replace it.
                              Check if there is leak of electric current
