Ecosys M6230cidn casette empty message
  • Alkeros
    • Oct 2022
    • 10
    [Jamming] Ecosys M6230cidn casette empty message
    hi everybody,
    i have a M6230cidn that gives me the message that the casette is empty even though the casette is full. sometimes it accepts that the casette is full but when i print a job it stops after 5-6 pages and says that the casette is empty. i'm going back with another casette tomorrow maybe the lifting mechanism is busted. i can hear the lift motor working tough.
    Any other ideas?
    • 22999
    Re: Ecosys M6230cidn casette empty message
    Have you looked at the paper empty flag yet? They can get bent, damaged.
    Also the paper size switches wear out.
    Do you hear any load clicking when the paper lifts?
    • ntbann
      • Jan 2012
      • 627
      Most likely its what BC said. Look at the white arm. If its bent you will see a stress mark in the plastic. I usually flip them onto the front to see.
      • Alkeros
        • Oct 2022
        • 10
        Last week i finally got to fixing the problem (i also had to preplace a black drum and it took forever for the part to arrive). The white arm was indeed broken. thanks for the tip!
        • fishleg
          • Mar 2009
          • 426
          The cassette on these is awful would love to know why they didn't make it spring loaded and do away with the ancient dial on the front. Just have it on the screen set paper size...
          The tray with a gear and motor driven lift is so bad. The white arm is horrendous tray goes in then makes it drop and it's kinda bent when new so it's almost impossible to guess how it should look.
          My rant for the day here's hoping to a design change...
            • 22999
            You may not think so, but Kyocera watches these boards. Here's an example:
            A few years ago (12 yrs?) I was calling the hotline frequently to get information about the undocumented "Engineering Codes". It was like pulling teeth! Nothing in the manuals, no bulletins, the hotline released very little ... This was in the days when D-Net was thriving. I started a thread amongst the elite Kyocera guys at D-Net: What are your experiences with CFxxx codes? Which codes? How did you fix? ANY information you have? ... and I put it together in an Excel spreadsheet, posting it into the thread. A couple of weeks later Kyocera decided to release a bulletin about the meaning of CFxxx codes. There were no real fixes in the bulletin, but they did define the codes in a way that made it more understandable. And I think we would still be guessing if I hadn't started that thread.
            So they may never admit it, but they are watching. =^..^=
              • 16312
              Very cool story. Thanks for sharing.
              • fishleg
                • Mar 2009
                • 426
                Hope they watch can DM me I have a million ideas for them 😂.
                  • 22999
                  Post them here, and they'll take the credit in a bulletin. ^..^=
