kyocera ecosys m3655idn - Error 4401 - Duplex sensor 2 non arrival jam
  • Xandy_73
    • Oct 2023
    • 29
    I have a Kyocera M3655idn giving me peace of mind.
    If I send 10 pages, it prints 10 in double-sided mode, if I send another 10, it makes a noise like gears slipping and the paper jams in the duplex area.
    New compatible fuser, new tray 1 feed rollers, new tray retard roller, I cleaned the duplex rollers and those two larger ones.
    Does anyone have an idea what could be happening?
    Printer has just over 100k
  • copiertec
    • Jan 2016
    • 2211
    Re: kyocera ecosys m3655idn - Error 4401 - Duplex sensor 2 non arrival jam
    Have you tried feeding paper though the bypass tray? When you say compatible fuser, is it an OEM Fuser? What issues did you have before you changed all these items? Was it the same issue?
    • Xandy_73
      • Oct 2023
      • 29
      Generic fuser, before changing the fuser, tray 1 pickup rollers, and retard roller.
      The printer worked for about 15 days then started to show error 4401 jams.
      When this error occurs, it makes a noise like gears slipping. I don't know if it's because of the jam or if some mechanism gets stuck and then the paper jams.
      Simple printing does not occur just duplex.
      • copiertec
        • Jan 2016
        • 2211
        What was the reason for changing these items? Did you have the non arrival jamming issue before changing these items?
        • Xandy_73
          • Oct 2023
          • 29
          Fuser was damaged, feed and retard rollers were worn.
            • 23009
            Have you cleaned DUS2? It sits on the HV PWB horizontally, and can fill up with paper dust. =^..^=
            • Xandy_73
              • Oct 2023
              • 29
              I removed this plate and blasted it with air
                • 23009
                Can you view the sensor from below? Or is it on the other side of the PWB? =^..^=
                • Xandy_73
                  • Oct 2023
                  • 29
                  Is on the other side.
                  I cleaned the side where the sensors are too.
