Ecosys m6635cidn Vertical Black marks
  • EDSNOW
    • 187
    [CQ] Ecosys m6635cidn Vertical Black marks
    I have a MK on order but no ETA
    I am thinking either black drum unit or transfer belt problem.
    Any input always appreciated.
    Sample enclosed.
    Ed in Whitehorse
    • 23009
    Re: Ecosys m6635cidn Vertical Black marks
    It's all about elevated internal temperature, fusing black waste toner to the drum surface. Start by shortening up the sleep timer to 5 minutes. Then replace the black drum. There is a new style black drum, but the sleep setting makes the most difference. All the Mebius, Mebius2, and Gemini machines suffer this ailment.
    https://www.copytechnet.com/forums/k...ml#post2476743
    • EDSNOW
      • 187
      Many thanks Blackcat.
      When the MK shows up I will apply your suggestion.
      In the meantime I will adjust the sleep time.
      Best Regards
      Ed
      • copykat93
        • Oct 2021
        • 277
        Also, there is a new firmware update that adjusts the sleep temp to almost off, Keeps it pretty cool.... The latest F.W. update is dated August 7, 2023 (2V0_S000.004.003)
        • EDSNOW
          • 187
          Thanks for the response
          I will update the firmware as well.
          Regards
          • darry1322
            • Oct 2010
            • 817
            Best Regards
            Ed
            The MK ships with the old style drum so the marks may come back after the MK is installed.
            If you've done everything already suggested and the marks come back you'll need to swap in the new drum. PN : 302NR93180
            • EDSNOW
              • 187
              Much appreciated information.
              Regards
              • EDSNOW
                • 187
                Regards
                Just to advise that the M-Kit arrived and is installed. Works well now.
                Thanks as always to everyone.
                Have a great day.
