Getting color lines only while doing scan
  • smartbipers89
    • Sep 2014
    • 3
    Hi all,
    I'm facing a problem in kyocera Mita task alfa 3212i machine
    While doing scan to folder I'm getting a yellow or red or both line in image but not not in
    Printout ,
    It comes only while doing scanning and also not continuously
    Eg: if we take 50 to 100 scanning, some 3 to 6 pages I'm getting lines
    In the attachment
  • Ropariva
    • 674
    • ntbann
      • Jan 2012
      • 628
      Re: Getting color lines only while doing scan
      Look like slit glass to me. There wouldn't be any voids in the feed direction if it were image process.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1885
        You need the chart to recalibrate the scanner unit.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • Scott
          • 196
          What he said right above my post, adjust scanner
          • dalewb74
            • Feb 2018
            • 1153
            my money is on as mentioned above. clean the adf slit glass. i have seen it many times. even when customer says it does not appear on copies.
            • JVergin
              Service Tech / IT Rep
              • 216
              Probably either slit glass (clean it even if you don't see anything), or the white sheet above the slit glass has something on it.
