weird bug on 3051
  • Scott
    • 199
    weird bug on 3051
    We are getting a odd bug on a 3051ci. We are getting a c9600 code it can be cleared using 906. It only happens when running legal. C9600 is a fuser fan issue, why only on legal?
    • 22994
    Re: weird bug on 3051
    Have you examined FUFM1 & FUFM2? It's not unheard of for fans fill with dust, get out of balance, and to fail. Especially near the fuser. Can you run those fans in U037 > Conv Edge > Start?
    Where do you find a reference to any code U9600? I don't see any reference. Are you talking about DP original jams J9600? That wouldn't have anything to do with fuser fans. =^..^=
    • CWP
      • Jun 2013
      • 168
      You probably meant C6900. The likely reason you see this with legal paper is that it is narrower (8.5 vs 11 lead edge). Try running letter size paper short edge feed and you will probably get the same error and it is likely exactly what blackcat mentions or simply a failed fan. That machine series is quite old.
      • dalewb74
        • Feb 2018
        • 1167
        it clears for a bit with 906? what about firmware?
        • CWP
          • Jun 2013
          • 168
          You probably have a bad fan. I doubt that U906 clears the code any more than completely powering the machine off and then back on would on its own.
