Re: Kyocera 4053ci lock's up from multiple apple air print ipads print job's in que.
Hello,
I have noticed this with one of our customers too. I have not found a fix but I did find a work around. You can download the mobile print application on their device and click share and look for the mobile print application and select the copier and it should print.
There have been a lot of issues with recent versions of ipads/macs. I would ensure that they have the most recent update as I believe they fix most of the weird printing issues.Leave a comment:
Have had similar Checking which iPads and wireless routers are involved. No solution as yet. Latest firmware.
Sent from my iPad using TapatalkLeave a comment:
Check firmware levelLeave a comment:
No problem printing from windows pc computers. (set to print after spooling in driver) But Apple air print from ipads got hung up in print que. As far as I can tell the air print driver does not allow (print after spooling), so while sending multiple print jobs from multiple ipads the copier shows that the jobs are processing but it just lock's up and have to reboot machine. Anybody else seen this or have a solution.
Thanks for any feedback.
