How Can i access to the Service Mode
  • dalewb74
    • Feb 2018
    • 1153
    #16
    Re: How Can i access to the Service Mode
    if you don't know how to access service mode with the other access code, given the code hasn't been changed. and you don't know where the NVRAM is located. you need to call a trained tech before you brick that machine.
    • Lunatech
      • Oct 2012
      • 208
      #17
      Originally posted by dalewb74
      ...you need to call a trained tech before you brick that machine.
      Assuming it is not too late already. I had a 3655 a few years ago that needed a NV ram and I was told it is the only part I can not get for the machine. Unfortunate, but I was able to use it for parts quite extensively. Hopefully it is not the case here.
