How Can i access to the Service Mode
  • AMIN0o0
    • Oct 2022
    • 8
  • copier tech
    • 8132
    Re: How Can i access to the Service Mode
    If the previous engineer changed the code you'll have to replace the NVram to reset the entry code back to default.
    โ€‹
    • AMIN0o0
      • Oct 2022
      • 8
      thank you for your respond. may I know should I Replace with new NV ram or just reinsert it ?
      • copiertec
        • Jan 2016
        • 2192
        You could try U21 or U2. Oh wait you can't get into service mode agreed with Copier Tech.
        • copier tech
          • 8132
          Replace it. But could be worth contacting Kyocera to see if the can supply the NVram reset tool / firmware.
          โ€‹
          • KYO_OEM
            • Aug 2011
            • 709
            only 1 short question.
            which screen do you see if you try to enter 1087 mode?
            Have seen that it won`t work if you are e.g. on copy screen.
            Select home screen, open the extension screen, select numeric keypad and enter 10871087.
            NVram you can`t change, it`s fixed on main pwb.
            You has to ask KDC tech for special USB file to get 1 time entrance by 10871087.
            Status page needed for this request
            By the way:
            on older systems like Mercury1, the new maintenance mode entrance code would stored on operation panel pwb instead of main pwb.
            • AMIN0o0
              • Oct 2022
              • 8
              By the way:
              I tried in copy screen, status , home screen, just abnormal thing that i have seen it was long and extended beep sound when I tried used numeric keypad, i tried same model machine but I have never seen like this
              • AMIN0o0
                • Oct 2022
                • 8
                • copier tech
                  • 8132
                  I can't see how this would help.
                  โ€‹
                  • AMIN0o0
                    • Oct 2022
                    • 8
                    How can I reset NV ram ? I've latest firmware and upgrade it but nothing happen...
                    • dalewb74
                      • Feb 2018
                      • 1125
                      you can contact a kyocera dealer/tech.... there is another code that you can use to access service mode. this code works if someone hasn't changed the codes. i do not share codes.
                      • AMIN0o0
                        • Oct 2022
                        • 8
                        Originally posted by dalewb74
                        you can contact a Kyocera dealer/tech.... there is another code that you can use to access service mode. this code works if someone hasn't changed the codes. i do not share codes.
                        I tried so many times to contact with them I said I'll charge you but there is not any respond (cause of competitions you know) . so if you are able to do I'll cooperate with you and I'll charge for this service.
                        • AMIN0o0
                          • Oct 2022
                          • 8
                          If i change PCB ? it should be work ?
                          • copier tech
                            • 8132
                            No, you need to replace the NVram chip with a new one.
                            โ€‹
                            • AMIN0o0
                              • Oct 2022
                              • 8
                              Is it located on mainboard ?
