Kyocera KM 4050 - black line
  • futre
    • Jan 2024
    • 3
    A thin black line appears at the bottom of the page in the same place. This only happens if there is some text on that part, both when copying and printing.
    Thanks for all your help.
  • KYO_OEM
    • Aug 2011
    • 721
    Re: Kyocera KM 4050 - black line
    Very very old system
    running direction?
    short edge feeding, long edge feeding or both?
    if short edge feeding maybe timing from transfer/ separation ON/OFF wrong
    check 2nd transfer area and paper path between transfer and fuser drive.
    Maybe paper stucks at the entrance from fuser unit, or it`s similar to old tomcat bulletin G146
    in case of long edge feeding-->maybe drum surface or dv unit
    • futre
      • Jan 2024
      • 3
      running direction?
      I put the same drum and dv unit in another device and this did not happen there.
      short edge feeding, long edge feeding or both? BOTH
      • Samanator
        • Sep 2017
        • 579
        Maybe check and clean the charger roller and blank lamps.
        • darry1322
          • Oct 2010
          • 817
          A broken transfer roller holder and spring can cause this type of issue. One end of the transfer roller will have no pressure from the spring.
            • 23009
            That's an image compression. It could be transfer pressure springs, or a broken fuser exit guide stalling paper passage. It's really common for those transfer latches to come unsnapped, and the springs to launch themselves. Somewhere along the way, the enduser notices that the transfer unit is unlatched and re-latches it-without the spring. Often the springs end up arriving at the bottom of the vertical paper path. If they're not mashed, sometimes you can re-install them. =^..^=
            • futre
              • Jan 2024
              • 3
              Problem solved. A spring was missing on one side. Thanks everyone for your help.
