AK-7110 Jamming
Re: AK-7110 Jamming
In the setup instructions there is a procedure for tightening the screws. I would start there. How about the fuser? Is it getting hard to turn?Comment
Re: AK-7110 Jamming
J6101 on 11x17.
It will jam from any cassette, or mp tray
I have also replaced the fuser, only about 50k copies o machine. I have seen the same issue on different machine. but most customers dont run 11x17
or run very little.
Re: AK-7110 Jamming
When you said you shimmed the paper pass unit, was that to push it tighter together? I would inspect that whole unit and check to see if anything has deformed or cracked, even a tiny one can cause issues. Also see if you can pass paper through it when it's out of the unit by turning the rollers by hand - but NOT putting pressure on them; to see if the rollers have enough pressure between them to pass the paper on their own.Comment
Re: AK-7110 Jamming
@toddanderson
seems to be a firmware problem from system if AK would installed on 4054ci.
Found similar case regarding J6101 only in case of 11x17 on several systems.
Set to thick/ heavy 1 solved the problem, but speed decreased for plain.
Finally change from exit motor speed fixed it.
J6101.JPGComment
Re: AK-7110 Jamming
@toddanderson
[ATTACH=CONFIG]61401[/ATTACH]Comment
Re: AK-7110 Jamming
Any definite solution to this AK-7110 jamming problem on 11 x 17?
I'm getting j4918, j4912 bridge conveying sensor 1 stay jam only on 11 x 17 with paper stalled about to exit AK-7110
I'm looking into the exit motor speed.Comment
Re: AK-7110 Jamming
Thanks KYO_OEM, I adjusted exit motor speed to -3500 in u053 motor 3 as shown above.
The 11 x 17 jamming problem seems to be resolved.
Could this adjustment also help cure 500x non arrival jams in the AK-7110?Comment
Re: AK-7110 Jamming
i don`t think so, but i would take care for the oneway pulleys #36 for the driving belts and the belts #37+38 itself.
J500x.JPGAttached FilesComment
