AK-7110 Jamming
  • toddanderson
    • Dec 2005
    • 235
    AK-7110 Jamming
  • KYO_OEM
    • Aug 2011
    • 710
    Re: AK-7110 Jamming
    Which jam code do you get?
    • Tonerkiller
      • Oct 2012
      • 668
      Re: AK-7110 Jamming
      In the setup instructions there is a procedure for tightening the screws. I would start there. How about the fuser? Is it getting hard to turn?
      • toddanderson
        • Dec 2005
        • 235
        Re: AK-7110 Jamming
        J6101 on 11x17.
        It will jam from any cassette, or mp tray
        I have also replaced the fuser, only about 50k copies o machine. I have seen the same issue on different machine. but most customers dont run 11x17
        or run very little.
        • ihatefinishers13
          Senior MFP Technician
          • Feb 2020
          • 680
          Re: AK-7110 Jamming
          Originally posted by toddanderson
          J6101 on 11x17.
          or run very little.
          When you said you shimmed the paper pass unit, was that to push it tighter together? I would inspect that whole unit and check to see if anything has deformed or cracked, even a tiny one can cause issues. Also see if you can pass paper through it when it's out of the unit by turning the rollers by hand - but NOT putting pressure on them; to see if the rollers have enough pressure between them to pass the paper on their own.
          • Rpizzle
            • Mar 2014
            • 47
            Re: AK-7110 Jamming
            How about checking if the paper stack limit plastic piece is still on the exit flag?
            I have not seen this on any of these units, with such a low count I have a hard time believing there is something broken.
            Keep us posted!
            • KYO_OEM
              • Aug 2011
              • 710
              Re: AK-7110 Jamming
              @toddanderson
              seems to be a firmware problem from system if AK would installed on 4054ci.
              Found similar case regarding J6101 only in case of 11x17 on several systems.
              Set to thick/ heavy 1 solved the problem, but speed decreased for plain.
              Finally change from exit motor speed fixed it.
              • fishleg
                • Mar 2009
                • 426
                Re: AK-7110 Jamming
                @toddanderson
                [ATTACH=CONFIG]61401[/ATTACH]
                Curious what mode is that? Interesting you'd think that would through all the timing out.
                • nathicana
                  • Aug 2008
                  • 329
                  Re: AK-7110 Jamming
                  Any definite solution to this AK-7110 jamming problem on 11 x 17?
                  I'm getting j4918, j4912 bridge conveying sensor 1 stay jam only on 11 x 17 with paper stalled about to exit AK-7110
                  I'm looking into the exit motor speed.
                  • nathicana
                    • Aug 2008
                    • 329
                    Re: AK-7110 Jamming
                    Thanks KYO_OEM, I adjusted exit motor speed to -3500 in u053 motor 3 as shown above.
                    The 11 x 17 jamming problem seems to be resolved.
                    Could this adjustment also help cure 500x non arrival jams in the AK-7110?
                    • KYO_OEM
                      • Aug 2011
                      • 710
                      Re: AK-7110 Jamming
                      i don`t think so, but i would take care for the oneway pulleys #36 for the driving belts and the belts #37+38 itself.
