Kyocera 5052ci blue background only when printing color
  • buzz
    • Aug 2013
    • 288
    There's a blue background only when printing color.
    Ran several DV and drum refreshes. Checked DV push button locks. Color only 128K and Blk 28K
    See samples
    Page from doc00714920240111003916.pdf
  • gregrcs
    • 22
    Re: Kyocera 5052ci blue background only when printing color
    How does the charge roller look ?
    • Ropariva
      • 669
      What have you done so far? Have you swapped drums around to eliminate the drum from the equation? Do you have another machine you can swap the dev in/out?
      Looks like you may have lost dev bias, so possibly a HVT or connection issue.
      Sent from my iPad using Tapatalk
        • 16385
        See samples
        [ATTACH]61637[/ATTACH]
        If you have another drum and DV unit, I'd try swapping and see if it corrects the problem.
        • jcg54
          • Jul 2023
          • 49
          Be wary of the secondary transfer roller in the door, You may have solved an issue and the transfer roller has picked up the toner and is continuing to make the pages blue.
            • 23006
            You need to try a new drum and/or developing unit, preferably both together. I suspect that the cyan developer is overtoning.
            • buzz
              • Aug 2013
              • 288
              Both on order, will do exactly this, thanks!
