Colour problems on taskalfa 400 ci
  • gloryhound
    Well can't say as I'm impressed with the Taskalfa's I how 2 in the field and have had nothing but trouble with one of them.
    Client prints about 20K prints per month in colour, by the
    2nd week.. black developed a line from some unidentified piece of plastic that gummed up and ruined the mag roller in the dev unit. (replaced)
    3rd week.. Magenta started leaving white lines on page, dev was chocked full of some sort of white foreign matter. (replaced)
    4th week.. Yellow starts to fade.. from front to back.. (replaced)
    5th week.. After Y dev had been replaced.. Yellow fades out completely.
    6th week.. All colours fade with the exception of black. A complete replacement on transfer, devs, and drums. All seems fine.
    7th week.. Cyan fades away to nothing.. This is starting to get tired. Kyocera provides a F/W update that might help
    8th week.. Replaced all Dev's F/W update and complete reset and recalibrate. Yay problem seems to have been beaten.
    9th week.. Normally printed Blue fonts now are printing purple, minor colour and image density problems with cyan at full bleed.
    The other machine exibited signs of having problems.. especially in even coming close to the colour desired.. These machines have been a complete disappointment from the beginning.
    Has anyone experienced this kind of series of colour problems?
    Electrical environment is good, voltage is good, cycle isn't sour..
    Temperature and humidity is within spec.
    Paper is good.
    Just can't get the same output twice on these machines.. it's like Fred Flintstone designed them
  • Eric1968
    • 2458
    Are you really sure the paper is of good quality? The white stuff could be paper dust. Maybe they're printing some sort of exotic media through the by-pass?
    • kyoceradude
      The Great Gazoo
      • Aug 2006
      • 442
      Something we got from our rep that might help......
      TASKalfa Copy Quality Check list follow in order as listed
      ________ 1. Install current firmware
      System menu
      ________ 2. System Menu > Arrow to 2nd page > adjustments/maintenance
      ________ 3. Drum Refresh
      ________ 4. Developer Refresh
      _______ 5. Color Registration > (Always perform Color Calibration after doing Registration this Prevents the Issue of registration changing a day or two later)
      _______ 6. Color Calibration
      Maintenance modes
      ________ 7. U464 > AC/ Calibration > Select All > Start
      After completed turn power switch Off/On
      _______ 8. U410 Continuous Adjustment
      If this fails then try this.......
      1.Replace DV unit (all colors)
      2.U147 set operation mode --> Mode2
      3.U464 (Set Calib Timing during Print) 1800 --> 480
      My mission here on Earth is to help all you Dum-Dums!
      • 10871087
        • Jan 2005
        • 1062
        The first problem your having is that Canadians constantly misspell the word "color".
        We probably have 15 or so machines out now and (knock on wood) they all seem good. Just a couple firmware updates so far but no failures. I do have a couple end-users that need some adjusting but the machines have been very good so far. I would follow Kyoceradude's recommendations and hopefully things will turn around for you.
        • dogsbody
          • Jun 2007
          • 289
          No he spelt it correctly, just like it is mum, gaol, etc.
          Off topic but I couldn't help myself. Sorry.
          Cheers.
          The force will be with you always.
            • 23008
            I have to agree with kyoceradude.
            I've only got (2) placed, but they're both doing more than 20K per month. Colour is consistent. there have been some problems with finisher error codes & CFxxx codes, but they have been resolved by the firmware.
            The most common problem I've seen on colour machines in general is techs skipping steps of the calibration. Do the whole calibration procedure and you should be golden. =^..^=
            • JSC
              Gimp
              • Dec 2006
              • 618
              I have had a couple giving poor quality, but since upgrading to the latest firmware all problems have gone..........
              The gene pool could use a little chlorine.
              • kyoceradude
                The Great Gazoo
                • Aug 2006
                • 442
                Damn, we have over 30 of these TASKalfa's and over 350 of the Voyager machines out there. So, we understand that proper procedures must be followed to eliminate problems. Do not skip any steps in setup or updates. Also make sure you use a good qualit of paper when performing Auto Gray adjustments. It takes a good hour to update firmware and follow CQ checks on the T/A.... We have several Voyagers (KM-C3232E) with over a million copies...
                • 10871087
                  • Jan 2005
                  • 1062
                  Cheers.
                  As long as you don't try to tell me that my car hood is really a bonnet.
                  Sometimes you just got to be off tipic to make it through the day.
