KM 5050 Main Charge
  • Brischaffer
    • Oct 2008
    • 68
    KM 5050 Main Charge
    Was wondering if anyone out there has ever tried to restring a main charge on the KM5050. I would like to have a spare when a machine goes down when Im on site.
    Brian
  • Jimbo1
    • Mar 2008
    • 845
    The experiences of myself and my collegues here has led us to that policy of we won't touch that corona unless we have to and I know of no one who has restrung one.
    Too many have tried to get in and clean them and when you put it back in you either have shading or solid black copy. You many notice they went away from that design in the later models.
    However I do carry a spare.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • aragul
      • Dec 2007
      • 128
      You can use a 2530-4035 (falcon 1-2) main charge in a pinch.
      I haven't needed to rebuild a falcon 3 main charge, yet.
        • 23010
        I haven't found a way to do this. By all appearances the grid has to be removed before the primary can be strung. I haven't had much luck with cleaning either. The image quality always coming out worse than before after cleaning.
        I usually stock a new primary unit, or a scrap primary unit that survived 500K to the PM.
        • Wile E. Coyote
          • Jun 2009
          • 10
          Brian
          Yes, and if you did for the first time, it's a bear. Better off to order the MC-710 ( assembly ) and practice on the old one.
          • SmudgerUK
            • Mar 2008
            • 17
            I have had to do a couple recently. I used the Canon silver wire that we use from Katun. Copies were not as crisp and clear after being restrung, but they looked ok on plain text (which is what most people do). Luckily both times were on machines with less than 100k to go before the next PM kit. Not sure what the implications would be if the charge had to last 400K.
