km c 3232 e
  • madhavanr
    • Mar 2009
    • 15
    km c 3232 e
    hai . i am having a problem with 3232e machines. some times the machine spill the toner all over the page, and some time background also. toner spillage and background on all colours, particularly black.
    when the customer printing more prints in atime the machine will give a colour background copy.
    is there any new firmware updation is there
  • cboucher
    • Aug 2025
    Does this machine have the new style developing units? The little white plastic spacers installed at each end of the mag roller will crack and cause problems on the old style developing units.
      • 23009
      CB is right (strange for an IT guy. They're never right.).
      It's usually the developing units on Voyagers, new style or otherwise. You cannot purchase developer starter separately, units only.
      • kyoceradude
        The Great Gazoo
        • Aug 2006
        • 442
        And yes, they updated the firmware in May 2009. Should be 35 on main and 31 on engine. Firmware should also take care of some CQ issues. How many copies are on the machine? Is it near a PM?
        My mission here on Earth is to help all you Dum-Dums!
        • Cirrus
          • May 2008
          • 43
          We have a lot of problems with color streaks on this machine. We have found that the cleaning units in the drum are poor. When everyting else is up to date we have just removed the drums from the units and vacuumed out the toner built up at the blade. This solves the problem for quite a while.
          • mdanaj
            I recomend to you download new firmware from May. You can see topics of thih firmware. In section 7 (bold) should by solution of his problem
            T
            OPIC:
            No Item Contents
            CTL FW
            1 Background image in
            the high coverage
            print and half speed
            mode
            New setting rages are implemented in U325 Setting the distance between pages
            to increase the distance by print coverage as measures against background
            image in the high coverage print and half speed mode. The distance between
            pages increases for the high coverage print with 5 ranks. Higher rank increases
            the distance more.
            362865
            361997
            MAIN
            319933
            ENG
            3 System error 640
            The IPU board senses an error and documents are not correctly deleted if
            refresh signal input for AE density is input in an irregular timing when saving
            documents in HDD. This is corrected for the system error 640 that is detected at
            the above case that may occur in high volume memory printing using HDD.
            327919
            MAIN
            4 Abnormal image at
            rotate sort
            Abnormal images are printed when rotate sorting in a continuous duplex
            scanning with auto magnification as size information is not correctly reflected
            Please refer to the next pages for the details
            316443
            MAIN
            5 Display when the low
            power mode is
            effected from FAX
            display
            The touch panel responds after the low power mode is effected.
            This is corrected.
            332449
            MAIN
            6 JAM05 after opening
            the DP cover
            JAM05 is incorrectly detected although it is JAM7x if the DP cover is opened
            during scan of the original without sorting. JAM 05 is not an existing jam code.
            288979
            MAIN
            7 Toner spillage
            (reverse motion of the
            cleaning roller)
            The cleaning roller reverse rotate control is added to remove toner may reside on
            the cleaning roller. The reverse rotation is in effect for BK and Y cleaning rollers
            according to the condition. A switch is added to U147 maintenance mode to turn
            on and off the reverse rotation. (default: 0FF)
            371157
            MAIN
            ENG
            8 Abnormal dot counting The toner dot counter may be 0 when setting U260 Selecting the timing for copy
            counting to FEED.
            361769
            ENG
            9 Incorrect size
            detection of the MPT
            Paper size may be incorrectly detected as B5E or B4 when setting the paper
            guide to the maximum width. It is changed to sense A4E or A3 size.
            361604
            ENG
            2/4
            No Item Contents
            CTL FW
            10 JAM31 JAM31 that is detected if the leading edge of paper is caught by the primary
            transfer belt. As the paper passes the registration sensor, the paper is not
            sensed by any paper sensor. Therefore, the jam sensing is clear after opening
            and closing the cover and the paper is further pulled in the primary transfer belt.
            This causes image failure and abnormal noise. JAM31 timer is shortened to
            eliminate the above failure.
            363653
            ENG
            11 JAM40 to 46 at fixing
            section
            Reverse rotation control is added for the fixing motor so that the paper end is
            surely sensed by the paper sensor in case A4E or LetterE size paper jams at the
            fixing section.
            • madhavanr
              • Mar 2009
              • 15
              thanks a lot friends,
              the machine crossed 200 thousand copies, still its running with the old developing unit, which is came along with new machine, we didnt changed it. only new modified fuser unit replaced, thats it.
              thanxs friends, i am trying to change the firmware, thanxs for all .
              • Craigdumass
                • Jun 2009
                • 61
                Very nice post MDANAJ I have been setting my rank to 5 on the machines that have been running card stock 200 at a time.
