error A4200 on kyocera km1635
  • weslan2002
    -I have changed the laser unit,main board,engine pcb,power board,exposure lamp, no changed at all.
    -when the machine is powered the error pobs on the screen
    - please advise
  • jewen25
    • Mar 2009
    • 197
    - please advise
    you said you change the laser? maybe the laser you change is also deffective?"A4200" is polygon motor problem try another LSU or laser i think thats the problem
    ERROR HELP ME AND HELP YOU
    • aodtech
      • 194
      Do you hear a loud whining noise, aside from the customer at this point? (Rimshot). That's the main indication that the Laser Unit is bad. But normally you'll get just a 4000 code. Try a different Main Charger. Arcing can do some crazy things.
      • JustManuals
        • Jan 2006
        • 9838
        Don't you mean error C4200?
          • 23009
          On Kyocera Mita machines the codes are grouped by type, so that all "4000" series codes are related to the laser, all "6000" series codes relating to the fuser, etc.
          The terms are not precise, but the advice is still good . =^..^=
