C6050
  • JASON
    C6050
    I HAVE A MITA KM-1650 WITH A C6050 CODE THAT WONT CLEAR. I KNOW ITS A FUSER CODE BUT EVERYTHING CHECKS OUT OK? WHAT AM I MISSING. HELP!
  • raym
    • Apr 2005
    • 62
    Re:C6050
    i don\'t know how much info. you have on this m/c, but that code does point to a low thermistor temp. i\'m thinking you probably know that you have to run sim#163 to reset error. with that in mind i can only tell you what book says:
    1)poor contact in therm. connector terminals.
    2)broken therm. wire
    3)therm. installed incorrectly
    4)fixing unit thermostat triggered
    5)fixing heater M or S installed incorrectly
    6)broken fixing htr. M or S
    hope this helps. if not, write back with more detailed info. and i\'ll try to help.
    good luck,
    ray
