Kyo 500CI
  • ExOceMan
    • Sep 2009
    • 63
    Kyo 500CI
    Does anyone know an acceptable voltage range for these machines? We have one installed that will dip from roughly 117vac to as low as 108. I would think that this sort of swing isn't exactly desirable, but I am not sure that it is our of tolerance. Any help here would be appreciated.
    • 23010
    The rule is typically +/- 10% of 120vac. So your low end is 108vac.
    If you can identify 108 with your meter, you can be sure that it drops even lower than that. I would get the power quality analyzer onto that line and document it. =^..^=
