KM-5050
  • westy
    • Aug 2025
    KM-5050
    Having problems scanning large amounts of documents to e-mail addresses on our internal LAN. Error message 2204 appears (sometimes when scanning as little as 5 sheets). Any advice?
  • B0265
    • Jan 2007
    • 718
    Change the [E-mail Size Limit] in [Advanced] - [SMTP] - [General] - [E-mail Setting] in COMMAND CENTER (Web interface).
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1888
      What B0265 said. Also change to mono scanning instead of color & change resolution.
      2204 Error: E-Mail Size limit
      The size of E-mail exceeds its
      limit.
      [Advanced]-[SMTP] -[General]-[E-mail Setting]
      in COMMAND CENTER.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • westy
        Tried that. Generally use mono with lowest resolution & still generally can only scan max 15 pages
        • tmaged
          • Oct 2008
          • 1888
          Is it set up to scan SMB ? I'd think if you get an error scanning to a shared folder, you have a RAM issue.
          Hope that helps !
          -Tony
          www.dtios.com
          • Jules Winfield
            • Jul 2009
            • 821
            There may also be size limits imposed by your SMTP server on attachments. If that's the case, then there is nothing you can do on the MFP end to correct that. The size limit would have to be changed or removed on the SMTP server.
            But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
            • westy
              Can't locate these settings - sorry but i'm not too technology savvy!
              • westy
                Cheers. I'll look into
                  • 23009
                  Not much that I can add here. 20MB is a realistic attachment size for most email servers, though I've seen a few accept 37MB. =^..^=
                  • RRodgers
                    • Jun 2009
                    • 1947
                    I usually see 10 mb max. But, that's out here in Cali!! LOL
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      You'll really need to check with your customer's IT department to see what the limit is. Until you know that, you're working completely in the blind.
                      Quite frequently, the limit for internal addresses is higher than what is is for external ones.
                      It also depends greatly on what type of documents you're scanning. Pages with a bunch of graphic coverage will be considerably larger than text.
                      • tmaged
                        • Oct 2008
                        • 1888
                        My guess is he's an end user.
                        Hope that helps !
                        -Tony
                        www.dtios.com
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3944
                          Methinks you're right.
