Hello all I have a copystar cs-1510
  • Halo
    • Aug 2025
    and When I turn it on it gives me a A 400 error code I try searching here for erroe code with that copier but no luck, Any ideals Thanks
  • charly
    • 65
    a 400----laser scanner unit issue-----polygonal motor blocked-----try to unlock it and if you fail you will have to change
      • 23009
      There is one situation where it could be something easy.
      If the machine was left out in the cold car overnight then delivered the next morning, the polygon mirror would be cold in the newly warm environment and collect condensation. Simply waiting a few hours to let the machine acclimate (and allow the condensation to dry) might be enough to solve this problem. Otherwise I agree with charly. =^..^=
      • Halo
        Thanks for the replys.
          • 23009
          Correction!
          C4000 is a laser error
          A0400 is some sort of communication issue between PWBs or accessories. Most often you can just power off/on to reset.
          I don't have the manual for this one, so I can only make an educated guess based on the error number. Sorry about the confusion. =^..^=
          • charly
            • 65
            km 1510 used the 3 digit codes
            • anthony123
              • 62
              You can get the trouble codes for this machine here: Home probably going to have to replace mirror motor I have tried removing and lubing lasted for a while but came back. good luck....... Ant.
