CS-3050 with DP-700 problems
  • Dave10
    • Jul 2008
    • 197
    We have a CS-3050 with a DP-700 that will not copy from the feeder. When you put a document in the feeder, it says, "waiting-adjusting scanner." It will copy from the glass, will print, etc. We checked sensors, cables, everything. We then tried replacing the entire feeder. No help. So, the problem is probably in the machine itself. Anyone seen this before?
    • 22973
    Check the DP top cover interlock or rear latch. My bet is that the enduser didn't use the handle to open the DP, and snapped off the rear latch. As a test, hold down the DP top cover, power Off/On, then try the DP.
    The machine is trying to do a shading adjustment for the CIS, but it won't complete because the CIS is not all the way down against the white reference roller. =^..^=
    • Dave10
      • Jul 2008
      • 197
      We tried replacing the entire feeder but it didn't help. Today , we are trying the scan board and the scanner home position sensor, and possibly a hard drive reformat. Will keep you posted.
        • 22973
        You might check for bent pins in the lower DP connector (for the CIS). Good luck. I'll be watching this post. =^..^=
        • Dave10
          • Jul 2008
          • 197
          We went back and found a paper clip in the contacts on the end of the CIS, which took out the CIS unit, the controller board in the feeder and the scanner board! What a lot of damage a paper clip can do. This is why a new feeder didn't fix it, because the scanner board was also shorted. We will have to charge for a whole new feeder.
            • 22973
            That was a costly little paper clip. =^..^=
            • djdlaay
              Hey
              Often you will get this message if your interlock switch on the rear right side of the DP itself, isn't engaging properly, or you didn't put the actuator bracket on the mainframe.
