km-1820
  • luis8832
    • Dec 2008
    • 250
    km-1820
    I have a km-1820/the customer said the unit was saying drum low. We changed the process unit and now the unit stays stuck on the kyocera screen. On the bottom there are bars when it boots up. It only goes as far as seven bars.I tried to do a firmware upgrade on the unit and it will not take at all. It stays on the same screen. Any suggestions?
    • 22999
    The firmware DIMMs on the machine is embedded in the main PWB and engine PWB respectvely, and it could be either. Flip a coin, heads for main PWB, tails for engine PWB.
    • xeroid
      Document Technologies Pro
      • 148
      I had that 7bar lock @ boot once on an 1820. It turned out to be a main pwb.
      • luis8832
        • Dec 2008
        • 250
        thanx i will try both and let u both know the verdict. thanx for your help.
