I am stumped km5035
  • Dustin(WOP)
    • 223
    I am stumped km5035
    hello all
    I have an km-5035 giving me some trouble. I am getting gray streaks on the front side of machine. I have replaced the drum unit, dev unit, transfer roller assembly, and the fuer unit. After replacement of each unit the problem got better but still not gone. I am not to sure what to try next. Any ideas on this??
    (I have attched some examples, they arent very good to see the accual problem I have to turn my scanner exposure all the way up to get the scan to pick it up)
    I am mostly a Sharp tech so not really to sure where to go with this machine, please help.
  • Lotar
    • 76
    have you checked the laser scanner ?
    • randula7
      • 73
      check developing bias control voltage,transfer control voltage, and the separation control voltage with U101. stop paper befor fuser unit check is it same prob or not then check fuser control temperature.did you clean machine with blower?if it is yes check Laser unit. did you clean Laser unit ?
        • 23009
        It appears from your scans that there is developer on the page. Possible severe undertoning. Is this OEM developer & toner? What sort of Sim 25-1 readings do you get? =^..^=
        • Dustin(WOP)
          • 223
          thanks for all your replies. It seems that the main charge was the cause. not sure how or why that would cause a double image but hey its working now so I am not going to worry about it. thanks again.
