Copystar CS-1810 Re-occurrence of ADF taking several sheets at a time.
I believe I had also replace the Sep Pad in front of the sep roller "on a different machine" along with the ADF Pick-Up, Feed Sep Roller and Torque Limiter and that did not work. I did not get the chance to figure it out since they decided to buy a new machine from me. I will look into that Sep Pad mechanism a little bit more and try bending it away from the Sep Roller.
Thanks aragul.Comment
Okay, Here's the Up-date on this issue: (1) Prior to replacement of the Sep Pad Front on the ADF; i tried bending the Sep Pad Front as indicated by aragul. and that did not work, so positioned pad, back to its original angle.
(2) Replaced the White (yellow) Front Sep Pad on the ADF. As usual; my tests all went well at that time. It has been about two weeks since and have followed up with user but have not had a reply from User.
If i hear from user, will update this posting.Comment
Here's an Update: Finally got a reply from User as he indicated that the problem was still present. After further investigation/Isolation of the problem concluded that I should devote my attention to this assembly: Part Number 3BRO7060 Guide, Paper Feed. FYI: I have inspected this (PN: 3BR07060) several times prior and again just recently and it does not appear warped, cracked, broken and it is seated properly. Once I have finished troubleshooting this assembly, will then update this again. This far I have swapped Guide, Paper Feed from a different machine and installed the new Sep Pad Front on it and awaiting reply from User.Comment
im sorry TECH 59, but im trying to add something up base on my experience...it had happen to me before, i thought it was mechanical but i to my surprise it was electrical....im just trying to help....anyway GOODLUCK!Comment
happicopy, no apology required. I appreciate the help and all replies and I am very surprised that it was the wires. Please don't be discouraged for replying as i said; i do appreciate the replies and don't mean to offend anyone. I will most likely, on my next visit check the wires since you have brought it to light.Comment
