You guys need a good laugh. Ready? Envelopes!!!!!!
  • Jimbo1
    • Mar 2008
    • 845
    Sigh.....I have this customer that's a law firm. They have a KM-3050 and insist on running #10 envelopes through the bypass. Of course this works well sometimes and sometimes it wrinkles the bat crap out of it.
    Anybody any good at getting these things to be consistant? Already had to explian they are too cheap to run the A/C so they need to keep them fresh.
    Done laughing? Ideas?
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • 23009
    Ha ha ha ha ha....
    I hate envelopes for all the reasons you already know. Folded multiple layers of paper tend to skew, wrinkle & jam in the best environment. Throw in humidity and you can just forget it. There isn't even any sort of pressure adjustment on the Falcon III, not that it would help much.
    But you already know all this. =^..^=
    • madas
      • Aug 2008
      • 313
      Hi, Jimbo1
      Try this brand if you can get them. told they work well in Kyocera printers but i have not tried them in the copiers.
      } Use DL Envelopes from Tudor and Officeworks DL Peel-n-Seal
      ha ahahahahahahahaah (had to be said)
      Les
      • OMD-227
        Possibly adding insult to injury...... Get a Sharp. Most new Sharp MX/MXM machines have a function for printing onto envelopes without any creasing. By changing the fuser pressure (done automatically on the new series, done manually on first series MX), it allows the 2 layer paper envelope to pass through without creasing or jams. We have heaps of clients regularly using the Bypass with envelopes..... from the cheapest, crappiest stuff you can buy, through to top quality envelopes..... no problems.
        Say whatever you want about Sharp, but the envelope feature works great and I've never had a problem with it.
          • 23009
          I'm sure that you know the basic principles. Reduce fixing pressure (~3.0 mm nipp), increased fixing temperature (~190 C). The temperature adjustment is easy enough. You can even create a custom media type, but fixing pressure is fixed. The only option is to dig through that giant box of springs to find weaker springs. Then since it's a static setting there's always the risk that the 75 gm/m2 paper won't fuse. It sucks to be you. =^..^=
          • Morlock49
            • Mar 2009
            • 166
            Hah!! we solved this for one of our customers, we put a printer in just to do envelopes. saved us hours of work and enhanced our company reputation.
            this was after I did try to make a modified tray to sit inside the the #1 tray. fuser got me everytime. no real adjustment.
            Sorry folks, reputation removed by Just Manuals, because he's a sad little wanker
            • Jimbo1
              • Mar 2008
              • 845
              Yeah...well the Sharp isn't an option here. I used to work on those and have varied opinions. Lot's of it appears made by Mattell.
              If I go back out I may have to try the fixing temp. Haven't been there yet. He's about tired of trying different envelopes. Trying to shovel it into the lap of my service manager.
              Cdr. William Riker
              • Vulkor
                • Jun 2009
                • 946
                Sounds like you guys love "envelopes" like the Ricoh/Savin guys do
                Most of the Ricoh machines just wrinkle the heck out of envelopes as well.
                • 10871087
                  • Jan 2005
                  • 1062
                  "but the only reason we bought this machine was to run envelopes..."
                  • joelsa12
                    • Nov 2008
                    • 260
                    "The salesman said it would run my envelopes with no problems. He also told me the machine could print on card board, stuff envelopes while printing them, and it would never break. Are you the senior tech at your establishment? If not we need to get someone out here who can fix our machine."
                    • robscopyr
                      • Mar 2009
                      • 54
                      Tell them that running envelopes through the copier is bad for the enviornment, and if they continue to do it you will have to report them to the EPA.
                      • Jimbo1
                        • Mar 2008
                        • 845
                        We told them they need a printer with an envelope attatchment whixh of course we can sell them.
                        Cdr. William Riker
                        • vikingmita
                          • Nov 2008
                          • 163
                          for all you envelopelovers:
                          Xante: Products: Ilumina Digital Envelope Press
                          Straight Shooter Equipment Company
                          enjoy!
