KM-5050 Squishing Text
  • mrfuser
    • 1598
    Machine has low copy count, runs great. Only problem appears to be that the trail edge has a sort of blur to it. Seems to "squish" letters together about 1/4 to 1/2" in on the trail edge. Any ideas?
    Happens on prints and copies, even internal reports.
    Kelly
    • 22932
    When you say "squish", do you mean in the paper feed direction, or the crossfeed direction? Does it also affect self-prints, reports, (not-scanned images)? Is the rest of the image properly registered? =^..^=
    • mrfuser
      • 1598
      Yes, as I stated, it happens on prints/copies/internal report prints. Rest of copy looks fine.
        • 22932
        And.....?
        • 10871087
          • Jan 2005
          • 1143
          And.....?
          As in how it the squish oriented in relation to the direction of paper travel?
          AND
          Is it the same on all paper sources and sizes including the MP Tray?
          AND
          Does it happen on every page out of the machine?
          • mrfuser
            • 1598
            yes happens on everything. As paper leaves the machine it is on the TRAIL EDGE of the page. So, letter, (not letter-r), has squished print on right side of page when exits.
            • Jimbo1
              • Mar 2008
              • 845
              It's stalling for some reason when it exits. Check the one way in the switchback or more properly exit section.
              "Some days you get the bear, some days the bear gets you."
              Cdr. William Riker
              • vikingmita
                • Nov 2008
                • 163
                missing a spring on the transfer roller? that's my guess
