Color registration keeps shifting on task alfa solution
  • n25an
    • Jul 2008
    • 1030
    [CQ] Color registration keeps shifting on task alfa solution
    I contacted the help desk and was told to go into mode u467
    turn registration off
    then cycle machine off and on...
    then to print a registration sheet...
    sometimes this works if it does then go back into u467 and turn it back on...
    then go back to color registration and check...
    if it holds then you end...
    if it does not then you go into mode u467...
    make sure color registration is set to off...
    then exit out to main machine and go from there...
    you would then set color registration
    go back into mode 467 and turn color registration
    cycle power and check registration...
    settings would hold...
    with the task alfas however... they will drift back to the same bad color registration problem...
    this truly can be caused by the transfer belt but that is doubtful...
    here is the fix as presented by not the help desk but one of kycera's systems engineer...
    STEPS TO DO COLOR REGISTRATION
    PURPOSE FOR THIS DOCUMENT.
    IF YOU FIND THAT COLOR REGISTRATION KEEPS SHIFTING...
    STEP 1 RUN U119
    STEP 2 RUN U412
    STEP 3 RUN U464 AC CALIBRATION
    STEP 4 CYCLE MACHINE OFF AND ON
    STEP 5 RUN DRUM REFRESH
    STEP 6 RUN DEVELOPER REFRESH
    STEP 7 RUN COLOR CALIBRATION
    STEP 8 RUN COLOR REGISTRATION
    STEP 9 RUN GRAY SCALE
    I just thought someone would like to know...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
    • 22999
    With a few added steps (u119, u412), this is the typical color calibration on TASKalfa. =^..^=
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      Would this be applicable to the voyagers?
      Idling colour developers are not healthy developers.
      • Metalvoc
        • Sep 2008
        • 155
        The important thing that I've found is to always run Color Calibration after Registration. Running Gray Adjust does the same thing, since the machine runs calibration before starting. I don't recall having the same problem with the voyagers, but after all the registration problems I've had with the taskalfas, I am in the habit of making calibration my last step on all kyoceras.
        I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
          • 22999
          It's a little different, simpler with the Voyagers:
          STEP 1 Turn of Auto Color Registration in U467, exit service mode
          STEP 2 Turn on Auto Color Registration in U467, exit service mode
          STEP 3 RUN Developer REFRESH
          STEP 4 RUN COLOR CALIBRATION
          STEP 5 RUN COLOR REGISTRATION (detailed)
          STEP 6 RUN GRAY SCALE
          • aabarnes1
            • Mar 2009
            • 620
            STEP 2 Turn of Auto Color Registration in U467, exit service mode
            step 1 and 2 are the same! is this intentional blackcat?
            Grant me the serenity to accept the things I cannot change.
              • 22999
              Corrected: it was supposed to say "On" (but you knew that)
              I was just testing you. =^..^=
              • copytech,mike
                CopyTech,MIKE
                • Jun 2014
                • 261
                Re: Color registration keeps shifting on task alfa solution
                [QUOTE=blackcat4866;222875]Corrected: it was supposed to say "On" (but you knew that)
                I was just testing you. =^..^=[/QUO
                I have a CS3253CI It wont let me run the u119. Not sure why. Put in 4 new drum units whith copier on (had no idea it should be off) no other machine requires to be off when install new drums), all dum counters apear clear to 0 except cyan drum. This is a really strange model! I better stick with Konica Minolta or Canon!
                  • 22999
                  For an Iris II check that the rubber shipping spacers have been removed from the developing roller. Check that the developing roller shifts smoothly at the front & back when you press the actuator. =^..^=
