where can i download "LPR jar utility"
  • NeoMatrix
    Senior Tech.
    • 3513
    #16
    Re: where can i download "LPR jar utility"
    Originally posted by copycoan
    Have u tried printerultility.exe, it is and executable file,does not require installation only you need the driver installed, and allows you to send prescribe commands and many other options and configurations.
    [ATTACH=CONFIG]30448[/ATTACH]
    How big is the actual *.exe file. ?
    I'm looking for mostly platform portable applications.
    Being part of the Kyocera software suite it would be fully installed an listed in the Windows Registry.
    That means it most like will not run on a USB stick when used on another machine.
    Looks ok from the screen shot.
      • 23010
      #17
      The executable is about 4MB, but that doesn't necessarily tell you how much more will be downloaded during installation. I'll be the guinea pig.
      • NeoMatrix
        Senior Tech.
        • 3513
        #18
        Do you have a download link , I'm coming up with hacked web sites ,but no URL ?
        Is it on the global.Kyocera website ?
          • 23010
          #19
          Right here sir:
          Malware scan of PrinterUtility.exe (Star Micronics Device Software) 55a080a4641e6aa68a92487ad71ebedce3504837 - herdProtect
          It's still untested, so use care. =^..^=
          • NeoMatrix
            Senior Tech.
            • 3513
            #20
            Machas gracias.....
            I don't understand the file download description : "reason-core-security-setup.exe."
            My Virus scan check the downloaded file all ok....
            What is the MD5 on your end.
            If your using the iTToobox there is a button in the SOFTWARE tray call HASH FILE: you can run SHA1 , MD5 etc test with that function.
            You can move the Hashfile.exe app out of the software and run in from command prompt. Let me know if theres any bugs with it.
            HASH MD5 = 5F8CA62A497076D139DC9429252E3BA2BD868F1C
            • copycoan
              • Sep 2012
              • 31
              #21
              from kyocera ftp repository
              P: kyocera
