Kyocera TASKalfa 250ci SMB scan to Windows 7
    • 23009
    #16
    I've used this on a couple different occasions. It works great.
    Thanks Tony. =^..^=
      • 30294
      #17
      most ricoh's you can browse the network from the op panel kyocera don't do that, if Kmnet viewer can't see the folder its not shared correctly.
      • Lotec
        • 97
        #18
        YES!!!
        Thanks guys
        Now it's working perfectly. It seems that I had entered a wrong Login User Name (I had not entered the domain name), and I think I had to open the port in the firewall too (not sure about that yet - but will test it).
        I had tried so many combinations - but non was correct.
        With the step by step guide fro
        m tmaged and a few good tips from you guys it work. I now understand why some of you said it was easy. ... when you know how to do it
        So now I'm going to all the customers and set up SMB scanning whether they want it or not
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1888
          #19
          Glad to help you Lotec.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • charly
            • 65
            #20
            Originally posted by Lotec
            Thanks guys
            when you do not work on smb you can also use the latest version of the file utility
            • TJ001
              • Nov 2009
              • 27
              #21
              On Windows 7 you sometimes have to go to print/file sharing advanced and check all the settings there as well. sharing enabled,Password off etc.
              • TONERINMYNOSE
                • Aug 2010
                • 114
                #22
                Need to go into network sharing center and turn off "password protected sharing"
