kyocera 3035 lead edge problem
  • GMAN1965
    • Jul 2025
    only one the fourth copies lead edge move about 1.5 inches and then goes back correct and back bad agin. Can anyone help
  • Jimbo1
    • Mar 2008
    • 845
    Check your reg clutch. Better yet replace it.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • GMAN1965
      already replace both clutches and feed drive motor, conveying section, feed heads. problem on both paper trays but not mpt tray
        • 23008
        Is it just a wide lead edge void, or is the whole image late on the paper?
        Have you cleaned or replaced the paper feed rollers, vertical path rollers, pickup clutches, vertical path clutches, registration clutch, checked the door fins for nicks, check the idler rollers for spring pressure & turning freely, checked that vertical path rollers turn freely, checked vertical path belt, ... you know, the usual stuff?
        • GMAN1965
          found problem it was LSU , and thank you for replys
