PF-760 etc. C1130 FYI
  • madas
    • Aug 2008
    • 313
    Hi Ithought I would post this as a new one to me.
    Had a bulk bin giving this code C1130 intermittently over a few months.
    A couple of techs visited the m/c cleaned the sensors checked the wiring unplugged and reset them and the m/c worked fine sometimes for weeks. Then it happened 2 times in 2 days, I went there and found no lift on the right side but the motor was turning. I removed the tray and checked for paper behind and found the spring loaded coupling was stuck back. I removed the motor and found the white plastic shaft with the sping coupling on was ever so slightly twisted giving a cork screw effect and locking the coupling fully back. This stopped the connection between the tray lift mech and the coupling resulting in the code.
    hope this is usefull.
    madas
    • 23009
    Cool! This is a common Ricoh issue also. Grease doesn't usually help. Occasionally I've taken the time to file out the keyed opening through the coupler, so it can return better. It's just one of the limitations of making drive shafts out of plastic.
    Thanks for sharing. =^..^=
    • LNorris
      • Sep 2008
      • 645
      Thanks, i have a 500ci doing this all of a sudden. have over 1million copies on it. i'll look at this motor and see if that is what i have going on.
