Taskalfa 300ci
  • Realtech
    • Oct 2009
    • 103
    Taskalfa 300ci
    I try to print a flayer in letter size but I see that it will not cover edge to edge 3mm on the square is white.
    How can I adjust this machine to cover the whole letter size.
    I need your help!
    • 23006
    My best device? Don't do it.
    The voids are there to prevent fuser jamming and wraps on the heat roller. If you diminish the lead edge void to anything less than 2.5mm you will get fuser wraps, and the resulting fuser damage when the customer gets out their pinking shears to cut out the offending paper.
    Laser printing engines are not designed to run without voids. If you do this you will be your own worst enemy. =^..^=
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1880
      Sell them a Sharp. They will do 12x18 so you can trim it down. There are none that will do full bleed edge to edge.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • Jimbo1
        • Mar 2008
        • 845
        Teach them to trim the border. It's all good.
        "Some days you get the bear, some days the bear gets you."
        Cdr. William Riker
