Control panel not responding or touch screen not responding ...... gonna go there and check for the obvious....stuck keys etc. Does this model have a history of problems like this? Any suggestions?
CS 2560 control panel
sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comTags: 2560, check, control, history, model, panel, pressed, responding, screen, stuck, symptom, touch, touch panel, touch screen -
It's very common to get some grit, or perhaps a curl of steel between the edge of the touch screen and the plastic panel opening. If the touch panel is being pressed in one place, the rest of the touch screen is unresponsive.
I've never had to replace a Stratos touch panel for this symptom. I have had to replace a whole panel assembly for cfB31 errors after loading firmware. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Thanks for responding....I got off easy. Stuck button on panel was the trouble.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
